Salta al contenuto principale
Amazon Kindle 8 Front Cover Replacement
Cosa ti serve
  1. Amazon Kindle 8 Front Cover Replacement, Front Cover: passo 1, immagine 1 di 2 Amazon Kindle 8 Front Cover Replacement, Front Cover: passo 1, immagine 2 di 2
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the screen gently so that it is not cracked.
  2. Amazon Kindle 8 Front Cover Replacement: passo 2, immagine 1 di 2 Amazon Kindle 8 Front Cover Replacement: passo 2, immagine 2 di 2
    • Insert the spudger between the inner cover and the screen.
    • Gently work your way around to loosen the front cover.
    • Carefully lift the front cover from the device.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 24
Tutti i Tempi: 317
