Salta al contenuto principale
Amazon Fire HD 8 12th Gen Speakers Replacement
Cosa ti serve
  1. Attenzione: i passaggi 1-2 provengono da una guida contrassegnata come in corso.
    Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: passo 1, immagine 1 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: passo 1, immagine 2 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: passo 1, immagine 3 di 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Speakers Replacement: passo 2, immagine 1 di 2 Amazon Fire HD 8 12th Gen Speakers Replacement: passo 2, immagine 2 di 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Disconnect the red and black wires connected to the motherboard.
  4. Amazon Fire HD 8 12th Gen Speakers Replacement: passo 4, immagine 1 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement: passo 4, immagine 2 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement: passo 4, immagine 3 di 3
    • Heat glue up to loosen the black and red wires, then lift and remove black and red wires.
    • Be careful of hot metals/parts and hot tools.
  5. Amazon Fire HD 8 12th Gen Speakers Replacement: passo 5, immagine 1 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement: passo 5, immagine 2 di 3 Amazon Fire HD 8 12th Gen Speakers Replacement: passo 5, immagine 3 di 3
    • Get metal speaker parts hot as well and lift the metal speaker up.
    • Do this for the other set of speakers and repeat the steps again.
    • Be careful of hot tools and hot parts.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 71
