Salta al contenuto principale
Amazon Fire 5th Generation Speaker Replacement
Cosa ti serve
  1. Amazon Fire 5th Generation Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Amazon Fire 5th Generation Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Ensure that your device is turned off.
    • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
    • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
    • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
    • Then, remove the back cover from the device.
    Chiedi a FixBot
  2. Amazon Fire 5th Generation Speaker Replacement: passo 2, immagine 1 di 2 Amazon Fire 5th Generation Speaker Replacement: passo 2, immagine 2 di 2
    • Pry the speaker from the case using the iFixit Opening Tool.
    • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
    • Be careful not to pull the speaker wires from the motherboard.
    Chiedi a FixBot
  3. Amazon Fire 5th Generation Speaker Replacement: passo 3, immagine 1 di 3 Amazon Fire 5th Generation Speaker Replacement: passo 3, immagine 2 di 3 Amazon Fire 5th Generation Speaker Replacement: passo 3, immagine 3 di 3
    Chiedi a FixBot
Conclusione
Amber Bunch
Membro da: 02/10/16
1.405 Reputazione
3 guide realizzate
USF Tampa, Team 1-2, Nance Spring 2016 Membro di USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 Membri
13 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 89
Tutti i Tempi: 1,662
