Introduzione
Use this replacement guide if the power port of the Amazon Echo Show 8 is not functioning. The power port is important to the device because it ensures it can properly function overall. Before continuing with this replacement guide, go to the troubleshooting guide ensure you have completed the troubleshooting steps, and make sure the power sport is clean. There are two components when powering the device, the port and the cord. This guide will walk you through replacing the speaker. Make sure the device is disconnected from the power before proceeding with the guide.
Cosa ti serve
Flip the device so that the rubber foot is facing up.
Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
Remove the rubber foot.
Lay the device face down with the power board facing you.
Use a T6 Torx screwdriver to remove the five 5.25 mm screws that secure the power board.
