Salta al contenuto principale
Aluratek ADMPF310F Remote Sensor Replacement
Cosa ti serve
  1. Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, immagine 1 di 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, immagine 2 di 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: passo 1, immagine 3 di 3
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Remote Sensor Replacement: passo 2, immagine 1 di 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Remote Sensor Replacement: passo 3, immagine 1 di 2 Aluratek ADMPF310F Remote Sensor Replacement: passo 3, immagine 2 di 2
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Remote Sensor Replacement: passo 4, immagine 1 di 1
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Remote Sensor Replacement, Remote Sensor: passo 5, immagine 1 di 1
    • Pull out the remote sensor from its holder with your hands.
    • Unsolder the remote sensor from the motherboard.
  6. Aluratek ADMPF310F Remote Sensor Replacement: passo 6, immagine 1 di 1
    • Resolder the the remote sensor back to the motherboard.
    • For more on how to solder check the link here.
Conclusione
Pascal Alexis
Membro da: 11/05/15
427 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 285
