Salta al contenuto principale
Introduzione
Replacing the motherboard will require soldering skills. If you need help soldering, check out the soldering guide. The motherboard is very embedded within the device and will require a spudger and Phillips #1 screw driver to separate it.
  1. Gently push down on the two tabs at the top of the battery door.
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Once the door is open, use your hand to pull out the four batteries.
    • Once the door is open, use your hand to pull out the four batteries.
  3. Pry off the control panel on top of the speaker using the metal spudger.  You may need to use a lot of force. Start in the middle and work your way around the perimeter.
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel. Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Desolder the three solders joints connecting the wires to the volume button circuit board. Do the same to the power button circuit board on the other side (the board with only one screw).
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
  6. Gently pry open the silver plastic lining of the iPod dock using the plastic spudger. It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
    • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
    • Remove the silver lining.
  7. Pry open the metal mesh by working the plastic spudger around the inside of the mesh. Once loose, lift up the metal mesh.
    • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
    • Once loose, lift up the metal mesh.
  8. Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
    • Remove the 7mm screw with the Phillips #1 Screwdriver.
  9. Carefully separate the front and back case plates at a corner of the speaker.
    • Carefully separate the front and back case plates at a corner of the speaker.
    • Lots of cables are still connected, so be very gentle when separating case plates.
  10. Guide the white button cables through the hole on the top of speaker case.
    • Guide the white button cables through the hole on the top of speaker case.
  11. Use your fingers to peel the glue off of the red and black cables.
    • Use your fingers to peel the glue off of the red and black cables.
  12. Careful not to touch the green capacitors or you might shock yourself.
    • Careful not to touch the green capacitors or you might shock yourself.
  13. Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
    • Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
  14. Repeat the previous step on the other side of the speaker.  There are two more 7mm screws on the filter mirroring the first.
    • Repeat the previous step on the other side of the speaker. There are two more 7mm screws on the filter mirroring the first.
    • Don't touch the green capacitors; you might get shocked.
  15. Don't touch the green capacitors.  They might shock you. Don't touch the green capacitors.  They might shock you.
    • Don't touch the green capacitors. They might shock you.
  16. Using the Phillips #1 screwdriver, remove the four 10mm screws from the corners of the motherboard.
    • Using the Phillips #1 screwdriver, remove the four 10mm screws from the corners of the motherboard.
  17. On the back side of the motherboard, pry out the connector to the filter using the plastic spudger.  You will have to use a lot of force. Pry out the second connect to the filter similarly.
    • On the back side of the motherboard, pry out the connector to the filter using the plastic spudger. You will have to use a lot of force.
    • Pry out the second connect to the filter similarly.
  18. Desolder the two battery connections from the motherboard. Do not touch capacitors to avoid being shocked.
    • Desolder the two battery connections from the motherboard.
    • Do not touch capacitors to avoid being shocked.
  19. Use the pointed end of the plastic spudger to pry the glue off of the iPod dock.  You will probably have to use some force.
    • Use the pointed end of the plastic spudger to pry the glue off of the iPod dock. You will probably have to use some force.
  20. Unlock the ribbon cable dock by pressing down on the two tabs at the bottom of the dock. Detach the copper ribbon cable by gently pulling it down, freeing the motherboard completely.
    • Unlock the ribbon cable dock by pressing down on the two tabs at the bottom of the dock.
    • Detach the copper ribbon cable by gently pulling it down, freeing the motherboard completely.
Conclusione
Altre 2 persone hanno completato questa guida.
Kirsten Mork
Membro da: 01/02/2015
270 Reputazione
2 Guide realizzate
Cal Poly, Team 17-33, Amido Winter 2015 Membro di Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 713
