Introduzione
Replacing the motherboard will require soldering skills. If you need help soldering, check out the soldering guide. The motherboard is very embedded within the device and will require a spudger and Phillips #1 screw driver to separate it.
Cosa ti serve
Gently push down on the two tabs at the top of the battery door.
While holding them down, slowly pull the door towards you.
Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
It is best to start from the top or bottom, then work your way around if it has not popped out yet.
Remove the silver lining.
Using a Phillips #1 screwdriver, remove the two 7mm screws from the filter.
Altre 2 persone hanno completato questa guida.
