Salta al contenuto principale
Alldaymall A88X Battery Replacement
Cosa ti serve
  1. Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: passo 1, immagine 1 di 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: passo 1, immagine 2 di 3 Alldaymall A88X Battery Replacement, Alldaymall A88X Back Cover: passo 1, immagine 3 di 3
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Battery Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Battery Replacement, Battery: passo 3, immagine 1 di 3 Alldaymall A88X Battery Replacement, Battery: passo 3, immagine 2 di 3 Alldaymall A88X Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to server any of these.
  4. Alldaymall A88X Battery Replacement: passo 4, immagine 1 di 3 Alldaymall A88X Battery Replacement: passo 4, immagine 2 di 3 Alldaymall A88X Battery Replacement: passo 4, immagine 3 di 3
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  5. Alldaymall A88X Battery Replacement: passo 5, immagine 1 di 2 Alldaymall A88X Battery Replacement: passo 5, immagine 2 di 2
    • Desolder the wires that connect the battery to the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Alex
Membro da: 02/10/16
101 Reputazione
1 Guida realizzata
USF Tampa, Team 4-1, Lacy Spring 2016 Membro di USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,117
