Salta al contenuto principale
Alcatel Pop 4 Plus Front Camera Replacement
Cosa ti serve
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: passo 1, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: passo 2, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement: passo 2, immagine 2 di 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: passo 3, immagine 1 di 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: passo 4, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement: passo 4, immagine 2 di 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: passo 5, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: passo 5, immagine 2 di 2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: passo 6, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: passo 7, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement: passo 7, immagine 2 di 2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: passo 8, immagine 1 di 2 Alcatel Pop 4 Plus Front Camera Replacement: passo 8, immagine 2 di 2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: passo 9, immagine 1 di 1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: passo 10, immagine 1 di 1
    • Disconnect the camera from the motherboard using the flattened of a spudger.
Conclusione
peter achanccaray
Membro da: 01/25/18
123 Reputazione
1 Guida realizzata
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro di USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 306
