Salta al contenuto principale
Alcatel One Touch Pop 7 Microphone Replacement
Cosa ti serve
  1. Alcatel One Touch Pop 7  Microphone Replacement, Back Cover: passo 1, immagine 1 di 1
    • Begin by opening SD port cover as this is the best location to start prying.
  2. Alcatel One Touch Pop 7  Microphone Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool to pry around the edges of the back cover until it pops off.
  3. Alcatel One Touch Pop 7  Microphone Replacement, Microphone: passo 3, immagine 1 di 1
    • Disconnect battery by pulling up on the ZIF connector with precision tweezers for safety.
  4. Alcatel One Touch Pop 7  Microphone Replacement: passo 4, immagine 1 di 1
    • Remove the Microphone from it's slot with the precision tweezers.
  5. Alcatel One Touch Pop 7  Microphone Replacement: passo 5, immagine 1 di 1
    • Solder the wires off of the motherboard with a soldering iron while holding the wires with the precision tweezers. For information on how to solder safely and correctly go to this link: Come saldare e dissaldare componenti elettrici
Conclusione
Philip Schenck
Membro da: 03/20/18
181 Reputazione
2 Guide realizzate
IUPUI, Team S6-G2, Baechle Spring 2018 Membro di IUPUI, Team S6-G2, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G2
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 821
