Salta al contenuto principale
Air Hog Smash Bots Motor Replacement
Cosa ti serve
  1. Air Hog Smash Bots Motor Replacement, Batteries: passo 1, immagine 1 di 1
    • Using the Phillips #0 screwdriver to remove the 8 mm screw.
  2. Air Hog Smash Bots Motor Replacement: passo 2, immagine 1 di 1
    • Lift and slide the batter cover away from the tab holding it in place at the bottom.
  3. Air Hog Smash Bots Motor Replacement: passo 3, immagine 1 di 1
    • Remove the 3 AAA batteries.
  4. Air Hog Smash Bots Motor Replacement, External Casing: passo 4, immagine 1 di 2 Air Hog Smash Bots Motor Replacement, External Casing: passo 4, immagine 2 di 2
    • Using a Phillip #0 screwdriver to remove the eight 8 mm screws.
  5. Air Hog Smash Bots Motor Replacement: passo 5, immagine 1 di 2 Air Hog Smash Bots Motor Replacement: passo 5, immagine 2 di 2
    • Remove the upper armor of the Smash Bot.
  6. Air Hog Smash Bots Motor Replacement: passo 6, immagine 1 di 1
    • Hold the upper body and slide out the bottom half of the Smash Bot.
    • The motor extends from the lower-body into the upper-body. Be careful to not damage the motor.
  7. Air Hog Smash Bots Motor Replacement: passo 7, immagine 1 di 1
    • Peel back the four decal stickers that hold the front and back of the bot together.
  8. Air Hog Smash Bots Motor Replacement: passo 8, immagine 1 di 2 Air Hog Smash Bots Motor Replacement: passo 8, immagine 2 di 2
    • Use the plastic opening tool to pry the front and back of the lower body apart.
    • Carefully remove the back of the bot from the front.
  9. Air Hog Smash Bots Motor Replacement, Motor: passo 9, immagine 1 di 2 Air Hog Smash Bots Motor Replacement, Motor: passo 9, immagine 2 di 2
    • Using the Phillips #0 screwdriver, remove six 4.75mm screws.
  10. Air Hog Smash Bots Motor Replacement: passo 10, immagine 1 di 1
    • Use the soldering iron to remove the blue and green wire from the motor casing. Directions on how to solder can be found here.
Conclusione
IUPUI, Team 1-1, Baechle Spring 2016 Membro di IUPUI, Team 1-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 164
