Salta al contenuto principale
Afterglow Wireless PS3 Controller Motherboard Replacement
Cosa ti serve
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: passo 2, immagine 1 di 1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 3, immagine 1 di 2 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 3, immagine 2 di 2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 4, immagine 1 di 2 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 4, immagine 2 di 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 5, immagine 1 di 2 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove two button padding from the back of motherboard.
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: passo 6, immagine 1 di 2 Afterglow Wireless PS3 Controller Motherboard Replacement: passo 6, immagine 2 di 2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
Conclusione
Natalie Cox
Membro da: 02/17/17
207 Reputazione
2 Guide realizzate
USF Tampa, Team S19-G5, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,237
