Salta al contenuto principale
Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: passo 1, immagine 1 di 2 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: passo 1, immagine 2 di 2
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
  2. Adjusting Contrast on TI-Nspire Calculator: passo 2, immagine 1 di 3 Adjusting Contrast on TI-Nspire Calculator: passo 2, immagine 2 di 3 Adjusting Contrast on TI-Nspire Calculator: passo 2, immagine 3 di 3
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
Conclusione
Now you should have the image contrast set to your preferences.
Alan Wong
Membro da: 09/26/12
63 Reputazione
1 Guida realizzata
Cal Poly, Team 7-52, Forte Fall 2012 Membro di Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,935
