Introduzione
If you have display assembly , Whether you've encountered a cracked screen, malfunctioning display, or other issues with your laptop or monitor, this step-by-step walkthrough will help you replace the display assembly and get your device back to optimal working condition. With detailed instructions and tips, we'll guide you through the process, ensuring a smooth and successful replacement of your display assembly.
Cosa ti serve
Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
Use a Phillips #1 screwdriver to remove the 5.5 mm screws securing the hinges.
Disconnect the display cable.
