Salta al contenuto principale
Acer Spin SP513-52N Charging Port Replacement
Cosa ti serve
  1. Acer Spin SP513-52N Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Power off your laptop before beginning disassembly and disconnect the device from the charger.
    • Use a Phillips #0 screwdriver to remove twelve 6.0 mm screws from the back panel.
  2. Acer Spin SP513-52N Charging Port Replacement: passo 2, immagine 1 di 2 Acer Spin SP513-52N Charging Port Replacement: passo 2, immagine 2 di 2
    • Use an opening tool in the seam of back case and slide it around the perimeter to release the clips securing it to the top case.
    • Remove the back case to reveal the internals of the laptop.
  3. Acer Spin SP513-52N Charging Port Replacement: passo 3, immagine 1 di 2 Acer Spin SP513-52N Charging Port Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Before replacing the charging port, unplug the internal battery from the motherboard.
    • Unplug the broken charging port from the motherboard with tweezers.
  4. Acer Spin SP513-52N Charging Port Replacement: passo 4, immagine 1 di 1
  5. Acer Spin SP513-52N Charging Port Replacement: passo 5, immagine 1 di 2 Acer Spin SP513-52N Charging Port Replacement: passo 5, immagine 2 di 2
    • Use tweezers to insert the new charging port securely.
  6. Acer Spin SP513-52N Charging Port Replacement: passo 6, immagine 1 di 1
    • Place the back case onto the laptop and press down around the edges of the perimeter.
    • You should hear the clips snap together.
  7. Acer Spin SP513-52N Charging Port Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #0 screwdriver to fasten the twelve 6.0 mm screws back into place.
Conclusione
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). Take your e-waste to an R2 or e-Stewards certified recycler.
Sara Al-Shumari
Membro da: 01/10/21
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,204
