Introduzione
If you notice your Acer Predator G9-791 laptop is silent and there is no airflow by the laptop vents, try replacing the fan using this guide.
This guide can also help if your laptop is overheating and you need to remove the fan to clean it or replace the thermal paste.
Cosa ti serve
The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
Remove the nine 4.5 mm Phillips #0 screws from the panel.
Remove four 14 mm Phillips #0 screws.
Remove six 7 mm Phillips #0 screws.
Remove the five 4.5 mm Phillips #0 screws located on the perimeter of the fans.
