Salta al contenuto principale
Acer Chromebook R11 C738T-C44Z Battery Replacement
Cosa ti serve
  1. Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: passo 2, immagine 1 di 2 Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Battery Replacement: passo 3, immagine 1 di 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Battery Replacement: passo 4, immagine 1 di 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
Conclusione
To reassemble your device, follow step one and two in reverse order.
Gateway, Team 1-4, Saknee Fall 2021 Membro di Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 473
