Salta al contenuto principale
Acer Chromebook CB3-532-C47C Touchpad Replacement
Cosa ti serve
  1. Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Touchpad Replacement, Remove the battery cable: passo 3, immagine 1 di 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: passo 4, immagine 1 di 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Battery: passo 4, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 5, immagine 1 di 1
    • Remove the battery from the laptop.
  6. Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: passo 6, immagine 1 di 2 Acer Chromebook CB3-532-C47C Touchpad Replacement, Touchpad: passo 6, immagine 2 di 2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  7. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 7, immagine 1 di 1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  8. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 8, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  9. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, immagine 1 di 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, immagine 2 di 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 9, immagine 3 di 3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  10. Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, immagine 1 di 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, immagine 2 di 3 Acer Chromebook CB3-532-C47C Touchpad Replacement: passo 10, immagine 3 di 3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
Conclusione
Sadie Brown
Membro da: 10/25/21
967 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 239
