Salta al contenuto principale
Acer Chromebook CB3-532-C47C Speaker Replacement
Cosa ti serve
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: passo 1, immagine 2 di 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: passo 2, immagine 1 di 2 Acer Chromebook CB3-532-C47C Speaker Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: passo 3, immagine 1 di 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: passo 4, immagine 1 di 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: passo 4, immagine 2 di 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: passo 5, immagine 1 di 1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: passo 6, immagine 1 di 2 Acer Chromebook CB3-532-C47C Speaker Replacement: passo 6, immagine 2 di 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: passo 7, immagine 1 di 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
Conclusione
Sadie Brown
Membro da: 10/25/21
967 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 152
