Salta al contenuto principale
Acer Chromebook CB3-111-C670 Battery Replacement
Cosa ti serve
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: passo 2, immagine 1 di 1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: passo 3, immagine 1 di 1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: passo 4, immagine 1 di 1
    • Remove the battery.
Conclusione
Altre 6 persone hanno completato questa guida.
Tony
Membro da: 01/20/16
459 Reputazione
2 Guide realizzate
USF Tampa, Team 10-5, Remmell Spring 2016 Membro di USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Membri
8 Guide realizzate
Un commento
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,134
