Salta al contenuto principale
Acer Chromebook C720-2844 Battery Replacement
Cosa ti serve
  1. Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, immagine 1 di 3 Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, immagine 2 di 3 Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Battery Replacement: passo 2, immagine 1 di 1
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook C720-2844 Battery Replacement: passo 3, immagine 2 di 2
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
Conclusione
Gateway, Team 1-2, Pee Spring 2022 Membro di Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 206
