Salta al contenuto principale
Acer Chromebook 14 CB3-431-C3WS Speaker Replacement
Cosa ti serve
  1. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 3, immagine 1 di 2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 3, immagine 2 di 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 4, immagine 1 di 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: passo 5, immagine 1 di 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: passo 5, immagine 2 di 3 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Battery: passo 5, immagine 3 di 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 6, immagine 1 di 2 Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 6, immagine 2 di 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 7, immagine 1 di 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement, Speaker: passo 8, immagine 1 di 1
    • Remove the four 4mm JIS #0 screws that hold the speakers in place.
  9. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 9, immagine 1 di 1
    • Disconnect the clip that connects the speaker wires to the daughterboard.
  10. Acer Chromebook 14 CB3-431-C3WS Speaker Replacement: passo 10, immagine 1 di 1
    • Lift the speakers from the frame, making sure to carefully unwind the wires connecting the speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 342
