Salta al contenuto principale
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
Cosa ti serve
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 2, immagine 1 di 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 3, immagine 1 di 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 3, immagine 2 di 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 4, immagine 1 di 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, immagine 1 di 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, immagine 2 di 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: passo 5, immagine 3 di 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 6, immagine 1 di 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 6, immagine 2 di 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: passo 7, immagine 1 di 1
    • Lift the battery out gently.
Conclusione
Altre 8 persone hanno completato questa guida.
3 Commenti
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - Replica
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 56
Tutti i Tempi: 5,493
