Salta al contenuto principale
Acer Aspire V5-571P-6815 Touchscreen Replacement
Cosa ti serve
  1. Acer Aspire V5-571P-6815 Touchscreen Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 2, immagine 2 di 2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: passo 3, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: passo 3, immagine 2 di 2
    • Insert a plastic opening tool between the screen and lid.
    • Work the plastic opening tool around the perimeter while prying upwards until the screen separates from the lid.
  4. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 4, immagine 1 di 1
    • Lay the screen flat down on the keyboard.
  5. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 5, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 5, immagine 2 di 2
    • Remove the camera using a pair of blunt nose tweezers.
    • Peel up the adhesive tape keeping the camera's cable tied down.
  6. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 6, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 6, immagine 2 di 2
    • Remove the microphone from the motherboard with a pair of blunt nose tweezers.
    • Slide out the adhesive tape securing the microphone cable.
  7. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, immagine 1 di 3 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, immagine 2 di 3 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 7, immagine 3 di 3
    • Lift up the ribbon cable contained by the adhesive strip with blunt nose tweezers.
    • This will allow you to access the two black digitizer ribbons.
    • Use a spudger to flip up the retaining flap on the digitizer ribbon cable ZIF socket.
    • Pull the ribbon cables out of their sockets.
  8. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 8, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 8, immagine 2 di 2
    • Remove the board from the laptop.
  9. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 9, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 9, immagine 2 di 2
    • Use the blunt nose tweezers to peel up the adhesive on the display cable.
    • Pull on the adhesive tape to disconnect the display from the motherboard.
  10. Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 10, immagine 1 di 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: passo 10, immagine 2 di 2
    • Lift the whole strip connected to the circuit board and LCD connector. Place the strip to the side where it is not in contact with the screen.
    • Remove the whole screen from the device.
Conclusione
UW Tacoma, Team S1-G4, Liner Spring 2018 Membro di UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Membri
8 Guide realizzate
Un commento
The heading of your Procedure is “Acer Aspire V5-571P-6815 Touchscreen Replacement” BUT you just opened up the entire screen.
NOTE: you didn’t separate the “TOUCH SCREEN” from the LCD screen.
This supposed to be the most important part of your procedure item ! ! ! !
PLEASE……. ******
KaivitiSingh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,366
