Salta al contenuto principale
Acer Aspire V5-571P-6815 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire V5-571P-6815 Keyboard  Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  2. Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 2, immagine 1 di 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 2, immagine 2 di 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  3. Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 3, immagine 1 di 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 3, immagine 2 di 3 Acer Aspire V5-571P-6815 Keyboard  Replacement: passo 3, immagine 3 di 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Jmarqu2
Membro da: 04/12/18
133 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G4, Liner Spring 2018 Membro di UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Membri
8 Guide realizzate
2 Commenti
This guide is wrong. All keyboard sold online come without the frame and replacing the keyboard is actually a very tedious process as it’s attached with melt plastic.
Sergey Ratakhin - Replica
Thank you! All this guide shows is how to take out and put in the exact same keyboard, which doesn't seem to be available anywhere. I've been looking for an exact replacement and haven't been able to find one. The original keyboard has the frame with the power button. NONE of the replacement options has ANYTHING with the power button.
Raul - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,295
