Salta al contenuto principale
Acer Aspire V5-571P-6815 Charging Port Replacement
Cosa ti serve
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 2, immagine 1 di 2 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 2, immagine 2 di 2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, immagine 1 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, immagine 2 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 4, immagine 3 di 3
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, immagine 1 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, immagine 2 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 5, immagine 3 di 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: passo 6, immagine 1 di 1
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 7, immagine 1 di 1
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, immagine 1 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, immagine 2 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 8, immagine 3 di 3
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 9, immagine 1 di 2 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 9, immagine 2 di 2
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, immagine 1 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, immagine 2 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 10, immagine 3 di 3
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 11, immagine 1 di 2 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 11, immagine 2 di 2
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, immagine 1 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, immagine 2 di 3 Acer Aspire V5-571P-6815 Charging Port Replacement: passo 12, immagine 3 di 3
    • Lift the charging port up and out of the laptop.
Conclusione
Follow the steps in reverse with a new cable.
Gordon Tran
Membro da: 04/12/18
225 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G4, Liner Spring 2018 Membro di UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 25
Tutti i Tempi: 5,590
