Salta al contenuto principale
Acer Aspire V5-571-6889 Display Assembly Replacement
Cosa ti serve
  1. Acer Aspire V5-571-6889 Display Assembly Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 3, immagine 1 di 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Display Assembly Replacement, Remove Upper Cover: passo 5, immagine 1 di 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 6, immagine 1 di 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Display Assembly Replacement, Display Assembly: passo 7, immagine 1 di 1
    • Remove the top left screw that is connecting the display assembly and the body of the laptop.
    • Remove the 2.5 mm by 5 mm screw by using #0 Phillips head screw driver.
  8. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 8, immagine 1 di 1
    • Using a #0 Phillips screw driver, remove the other 2.5 mm by 5 mm phillips screw that holds the display assembly.
  9. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 9, immagine 1 di 1
    • Gently disconnect the display cable connector between the display assembly and the motherboard.
  10. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 10, immagine 1 di 1
    • Remove the tape holding down the display cable that connects it to the motherboard.
  11. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 11, immagine 1 di 1
    • Disconnect the tape that is holding the white antenna cable to the motherboard.
  12. Acer Aspire V5-571-6889 Display Assembly Replacement: passo 12, immagine 1 di 1
    • Take the display assembly off and replace it with a new one.
Conclusione
Mohd Yuthly
Membro da: 07/08/19
154 Reputazione
1 Guida realizzata
IUPUI, Team S2-G4, Harley Summer 2019 Membro di IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 929
