Introduzione
This guide will show how to replace the cooling fan on the Acer Aspire V5-473P-5602. This part helps maintain the temperature of your machine. If your machine is displaying a message similar to “Cooling System,“ warmer than usual, or making noise, then you might want to consider replacing your cooling fan. This could be caused by a clog in the cooling system from dust, an accidental drop, or a spill.
Cosa ti serve
Flip the laptop over so the back panel is facing upwards.
Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
Remove the back panel from the laptop using an iFixit opening tool.
