Salta al contenuto principale
Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement
Cosa ti serve
  1. Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement, Secondary Cooling Fan: passo 2, immagine 1 di 2 Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement, Secondary Cooling Fan: passo 2, immagine 2 di 2
    • Unplug the cable that connects to the fan to motherboard.
  3. Acer Aspire V5-473P-5602 Secondary Cooling Fan Replacement: passo 3, immagine 1 di 1
    • Remove the two Phillips #0 screws that secure the fan to the base.
    • Remove the fan from the laptop.
Conclusione
Thuy Tran
Membro da: 01/22/20
267 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 277
