Introduzione
Changing the Battery in an Acer Aspire R7 is a straightforward process if you find your computer has lost its ability to hold a charge.
The Aspire laptop battery enables the computer to work without having a power cord. It is a hardware component that is not externally accessible and requires a small amount of disassembly to replace.
The 4-cell replacement battery instructions are listed below in quick simple steps. Before using this guide make sure that the battery can no longer function in one of two ways, use a multimeter to test battery strength or check the settings on the laptop if possible.
If the battery is swollen be careful and proceed with caution and take appropriate precautions.
Cosa ti serve
Locate the battery ribbon connector
Remove the ribbon cable attaching the battery to the motherboard by carefully pulling it outwards
Altre 12 persone hanno completato questa guida.
6Commenti sulla guida
great instructions
hey how do you want då sel it for
super tuto
Thanks
P.S : A have add a short comment on step 2.
Bests regards
