Salta al contenuto principale
Acer Aspire R5-571T-59DC Hard Drive Replacement
Cosa ti serve
  1. Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: passo 1, immagine 1 di 2 Acer Aspire R5-571T-59DC Hard Drive Replacement, Back Cover Panel: passo 1, immagine 2 di 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, immagine 1 di 3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, immagine 2 di 3 Acer Aspire R5-571T-59DC Hard Drive Replacement, Battery: passo 2, immagine 3 di 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the hard drive up and out of the laptop.
Conclusione
Altre 7 persone hanno completato questa guida.
USF Tampa, Team S20-G2, Passmore Spring 2018 Membro di USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Membri
7 Guide realizzate
Un commento
I have bent the pins on my ZIF socket for my Aspire Laptop. Do you have the product name and number or know where I could buy a replacement part?
Samwise - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 4,496
