Salta al contenuto principale
Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement
Cosa ti serve
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: passo 1, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 2, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: passo 3, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, immagine 1 di 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, immagine 2 di 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 4, immagine 3 di 3
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, immagine 1 di 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, immagine 2 di 3 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 5, immagine 3 di 3
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  6. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: passo 6, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement, Display: passo 6, immagine 2 di 2
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  7. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 7, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 7, immagine 2 di 2
    • Disconnect the two antenna cables from the Wi-fi card.
  8. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 8, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 8, immagine 2 di 2
    • Disconnect the display cable by pulling it down and towards you.
  9. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 9, immagine 1 di 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 9, immagine 2 di 2
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  10. Acer Aspire One Cloudbook 14 AO1-431-C8G8 Display Replacement: passo 10, immagine 1 di 1
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Conclusione
Joseph
Membro da: 01/25/18
685 Reputazione
6 Guide realizzate
USF Tampa, Team S20-G1, Passmore Spring 2018 Membro di USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,664
