Introduzione
This guide will show you all the steps to remove and therefor replace the motherboard for this laptop. Be sure to disconnect the AC laptop charger before removing the battery and continuing further. Removing component connection to the motherboard in these steps can be fallowed in any order, though the removal of the back casing should obviously be first, and the removal of the motherboard itself should be last.
Parti
Nessuna parte specificata.
Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
Remove the two 6mm Phillips #0 screws from the fan.
Disconnect the fan from the motherboard.
Remove the four 6mm Phillips #0 screws from the heat sink.
Lift and remove the heatsink assembly from laptop.
