Salta al contenuto principale
Acer Aspire E5-573G Battery Replacement
Cosa ti serve
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: passo 2, immagine 1 di 1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: passo 4, immagine 1 di 1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: passo 5, immagine 1 di 1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: passo 6, immagine 1 di 1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: passo 7, immagine 1 di 1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
Conclusione
Altre 15 persone hanno completato questa guida.
Alex Bahm
Membro da: 01/18/18
2.311 Reputazione
6 Guide realizzate
Cal Poly, Team S12-G5, Banghart Winter 2018 Membro di Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Membri
15 Guide realizzate
Un commento
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 66
Tutti i Tempi: 22,273
