Salta al contenuto principale
Acer Aspire E1-510P-4637 CMOS Battery Replacement
Cosa ti serve
  1. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 2, immagine 1 di 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 CMOS Battery Replacement, Hard Drive: passo 3, immagine 1 di 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 5, immagine 1 di 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 6, immagine 1 di 2 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 6, immagine 2 di 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, immagine 1 di 3 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, immagine 2 di 3 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 7, immagine 3 di 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 CMOS Battery Replacement, CMOS Battery: passo 8, immagine 1 di 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 9, immagine 1 di 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 10, immagine 1 di 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 11, immagine 1 di 1
    • Slowly rotate the back cover up to reveal cables attached to the motherboard.
    • Carefully slide the connectors out of their receptacle to remove the back panel.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 12, immagine 1 di 2 Acer Aspire E1-510P-4637 CMOS Battery Replacement: passo 12, immagine 2 di 2
    • Open the up the laptop to reveal the CMOS battery.
    • Desolder the CMOS battery to remove it. For soldering help, check out iFixit's soldering guide.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 34-15, Maness Spring 2016 Membro di Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Membri
6 Guide realizzate
2 Commenti
molto utile e ben fatta, anche se il mio problema è più legato alla alimentazione che pare non funzionare anche senza batteria
Franco Ferrandi - Replica
It'd be really handy if you were to list the model number of the CMOS battery so we can order one in advance.
Dave Compton (SirCompo) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 70
Tutti i Tempi: 17,876
