Salta al contenuto principale
Acer Aspire 5100 RAM Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Acer Aspire 5100 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
    Chiedi a FixBot
  2. Acer Aspire 5100 RAM Replacement, RAM: passo 2, immagine 1 di 3 Acer Aspire 5100 RAM Replacement, RAM: passo 2, immagine 2 di 3 Acer Aspire 5100 RAM Replacement, RAM: passo 2, immagine 3 di 3
    • Turn over Acer Aspire 5100 laptop so back of laptop is facing up. There are several removable covers, you want to remove the largest cover.
    • Get your screwdriver and remove four screws holding the compartment in place.
    • Slowly lift off backing compartment to expose laptop memory chips.
    Chiedi a FixBot
  3. Acer Aspire 5100 RAM Replacement: passo 3, immagine 1 di 1
    • Press down the locking levers to release the RAM.
    • Insert the new RAM. (Make sure to insert end with gold conductor end's first)
    • After RAM is put in place, press locking levers to secure the RAM.
    Chiedi a FixBot
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 61
Tutti i Tempi: 3,420
