Salta al contenuto principale
Acer Aspire 5100 Keyboard Replacement
Cosa ti serve
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Acer Aspire 5100 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: passo 2, immagine 1 di 3 Acer Aspire 5100 Keyboard Replacement: passo 2, immagine 2 di 3 Acer Aspire 5100 Keyboard Replacement: passo 2, immagine 3 di 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: passo 3, immagine 1 di 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
Conclusione
Altre 7 persone hanno completato questa guida.
Brad Rollinson
Membro da: 09/29/10
1.113 Reputazione
7 Guide realizzate
Cal Poly, Team 14-39, Forte Fall 2010 Membro di Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membri
10 Guide realizzate
1Commento della guida
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 13,523
