Salta al contenuto principale
AYL SoundFit Motherboard Replacement
Cosa ti serve
  1. AYL SoundFit Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: passo 2, immagine 1 di 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: passo 3, immagine 1 di 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: passo 4, immagine 1 di 2 AYL SoundFit Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: passo 5, immagine 1 di 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: passo 6, immagine 1 di 3 AYL SoundFit Motherboard Replacement: passo 6, immagine 2 di 3 AYL SoundFit Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
Conclusione
Altre 3 persone hanno completato questa guida.
john
Membro da: 03/10/16
171 Reputazione
1 Guida realizzata
IUPUI, Team 3-3, Harley Spring 2016 Membro di IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Membri
5 Guide realizzate
3Commenti sulla guida
Where do u get a new motherboard at?
calvinsmith522 - Replica
Anybody know where to get a motherboard?
David Whitman - Replica
Where do I get a motherboard?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,769
