Salta al contenuto principale
ATT EL52300 LCD Screen on Handset Replacement
Cosa ti serve
  1. ATT EL52300 LCD Screen on Handset Replacement, Battery: passo 1, immagine 1 di 2 ATT EL52300 LCD Screen on Handset Replacement, Battery: passo 1, immagine 2 di 2
    • Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
  2. ATT EL52300 LCD Screen on Handset Replacement: passo 2, immagine 1 di 1
    • Unplug the battery by squeezing your hands on the small white plug and lifting it up.
    • Do not pull on the wire itself because you might damage the wire!
    • The battery is now detached and ready to be removed by lifting it out.
  3. ATT EL52300 LCD Screen on Handset Replacement, Motherboard: passo 3, immagine 1 di 2 ATT EL52300 LCD Screen on Handset Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove the two 3.75 mm screws with a PH1 screwdriver.
  4. ATT EL52300 LCD Screen on Handset Replacement: passo 4, immagine 1 di 2 ATT EL52300 LCD Screen on Handset Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to remove the handset case.
    • Be careful to not lift the case too far as the ringer cable is attached to the case.
  5. ATT EL52300 LCD Screen on Handset Replacement: passo 5, immagine 1 di 2 ATT EL52300 LCD Screen on Handset Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
    • Use an anti-static wrist strap to prevent damage to the motherboard.
  6. ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: passo 6, immagine 1 di 2 ATT EL52300 LCD Screen on Handset Replacement, LCD Screen on Handset: passo 6, immagine 2 di 2
    • The motherboard is connected to the ringer, which is clipped on to the back plate of your handset.
    • Pop off the indicated clip using a pointed tweezer.
    • With the motherboard disconnected from the back plate, turn it over so that the screen is facing you.
  7. ATT EL52300 LCD Screen on Handset Replacement: passo 7, immagine 1 di 3 ATT EL52300 LCD Screen on Handset Replacement: passo 7, immagine 2 di 3 ATT EL52300 LCD Screen on Handset Replacement: passo 7, immagine 3 di 3
    • To get to the connection between the display and the motherboard, remove the casing for the display using a plastic opening tool.
    • The white casing has a hole cut into it. You are going to slide the display and the speaker through this hole.
  8. ATT EL52300 LCD Screen on Handset Replacement: passo 8, immagine 1 di 1
    • The display has a line of soldered connections to the motherboard. These all need to be undone with a soldering tool, so the screen can be removed.
    • Please refer to the Come saldare e dissaldare componenti elettrici for soldering help.
Conclusione
Katty
Membro da: 08/27/15
340 Reputazione
3 Guide realizzate
USF Tampa, Team 1-1, Sullivan Spring 2016 Membro di USF Tampa, Team 1-1, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G1
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 604
