Salta al contenuto principale
ATT CL4940 Motherboard Replacement
Cosa ti serve
  1. ATT CL4940 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 ATT CL4940 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Disconnect the phone line and power cord from the back cover of the device.
    • Disconnect the phone cable from the side of the device.
  2. ATT CL4940 Motherboard Replacement: passo 2, immagine 1 di 1
    • Turn the device over on its front so the back cover is facing you.
    • Use a bit driver to remove all five 4mm X 10mm Phillips head screws from the back cover.
  3. ATT CL4940 Motherboard Replacement: passo 3, immagine 1 di 3 ATT CL4940 Motherboard Replacement: passo 3, immagine 2 di 3 ATT CL4940 Motherboard Replacement: passo 3, immagine 3 di 3
    • Using a metal spudger, start at the bottom of the device to separate the top cover from the back cover.
    • Work the spudger between the top and back covers of the device starting downwards, then to each side, and finally upwards.
    • There are brackets every few inches along the edge of the device which may be difficult to pull apart.
    • The top and back cover will separate and the internals will be accessible.
  4. ATT CL4940 Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a bit driver to remove all five 5mm X 5mm Phillips head Motherboard screws.
  5. ATT CL4940 Motherboard Replacement: passo 5, immagine 1 di 2 ATT CL4940 Motherboard Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Lift the motherboard upwards as shown in the first image.
    • Use a de-soldering pump to disconnect the electric wires by de-soldering them.
Conclusione
Hongkun Zhu
Membro da: 09/16/15
263 Reputazione
1 Guida realizzata
IUPUI, Team 2-2, Harley Spring 2016 Membro di IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Membri
8 Guide realizzate
Un commento
But no option for ordering a replacement motherboard! Did the author get the part off of a scrapped unit?
Bruce England - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 18
Tutti i Tempi: 547
