Salta al contenuto principale
ATT CL2940 Speakerphone Replacement
Cosa ti serve
  1. ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, immagine 1 di 3 ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, immagine 2 di 3 ATT CL2940 Speakerphone Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Speakerphone Replacement: passo 2, immagine 1 di 3 ATT CL2940 Speakerphone Replacement: passo 2, immagine 2 di 3 ATT CL2940 Speakerphone Replacement: passo 2, immagine 3 di 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Speakerphone Replacement: passo 3, immagine 1 di 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Speakerphone Replacement, Speakerphone: passo 4, immagine 1 di 2 ATT CL2940 Speakerphone Replacement, Speakerphone: passo 4, immagine 2 di 2
    • Remove the front panel of the device as shown.
  5. ATT CL2940 Speakerphone Replacement: passo 5, immagine 1 di 3 ATT CL2940 Speakerphone Replacement: passo 5, immagine 2 di 3 ATT CL2940 Speakerphone Replacement: passo 5, immagine 3 di 3
    • Desolder the speakerphone with a soldering iron.
    • If you are unfamiliar with solder, check out the article on soldering and be very careful. The iron is hot!
  6. ATT CL2940 Speakerphone Replacement: passo 6, immagine 1 di 2 ATT CL2940 Speakerphone Replacement: passo 6, immagine 2 di 2
    • Use the soldering iron to reconnect the wires to the new speaker.
    • Place the new speaker back in place.
    • Make sure that all of the components are back in place.
Linea Traguardo
IUPUI, Team 1-1, Harley Spring 2016 Membro di IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Membri
13 Guide realizzate
Un commento
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 619
