Salta al contenuto principale
ATT CL2940 Handset Speaker Replacement
Cosa ti serve
  1. ATT CL2940 Handset Speaker Replacement, Handset Speaker: passo 1, immagine 1 di 2 ATT CL2940 Handset Speaker Replacement, Handset Speaker: passo 1, immagine 2 di 2
    • Separate the two sections of the handset by pushing them apart with the tip of the metal spudger or opening tool.
  2. ATT CL2940 Handset Speaker Replacement: passo 2, immagine 1 di 2 ATT CL2940 Handset Speaker Replacement: passo 2, immagine 2 di 2
    • Continue separating the two sections by using the metal spudger all the way around the edge of the handset.
  3. ATT CL2940 Handset Speaker Replacement: passo 3, immagine 1 di 1
    • After separating the two sections of the handset, it should look as shown.
  4. ATT CL2940 Handset Speaker Replacement: passo 4, immagine 1 di 3 ATT CL2940 Handset Speaker Replacement: passo 4, immagine 2 di 3 ATT CL2940 Handset Speaker Replacement: passo 4, immagine 3 di 3
    • Pull the speaker out gently to detach it from the handset. The speaker is located at the top end of the handset. It is the circular white piece with red and greed wires connected to it.
    • The speaker is attached to the handset with a slightly sticky adhesive.
  5. ATT CL2940 Handset Speaker Replacement: passo 5, immagine 1 di 2 ATT CL2940 Handset Speaker Replacement: passo 5, immagine 2 di 2
    • Use a soldering iron to melt the existing solder off of both the red and green wires in order to completely remove the speaker.
Conclusione
Noor Assaf
Membro da: 02/15/16
309 Reputazione
2 Guide realizzate
IUPUI, Team 1-1, Harley Spring 2016 Membro di IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 665
