Salta al contenuto principale
ATT CL2940 Buttons and/or Keypad Replacement
Cosa ti serve
  1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, immagine 1 di 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, immagine 2 di 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Buttons and/or Keypad Replacement: passo 2, immagine 1 di 3 ATT CL2940 Buttons and/or Keypad Replacement: passo 2, immagine 2 di 3 ATT CL2940 Buttons and/or Keypad Replacement: passo 2, immagine 3 di 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Buttons and/or Keypad Replacement: passo 3, immagine 1 di 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: passo 4, immagine 1 di 2 ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: passo 4, immagine 2 di 2
    • Unscrew five 5.6 mm screws on top level, yellow motherboard.
  5. ATT CL2940 Buttons and/or Keypad Replacement: passo 5, immagine 1 di 3 ATT CL2940 Buttons and/or Keypad Replacement: passo 5, immagine 2 di 3 ATT CL2940 Buttons and/or Keypad Replacement: passo 5, immagine 3 di 3
    • Lift the top level Motherboard in order to get to the lower level Motherboard.
  6. ATT CL2940 Buttons and/or Keypad Replacement: passo 6, immagine 1 di 2 ATT CL2940 Buttons and/or Keypad Replacement: passo 6, immagine 2 di 2
    • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
  7. ATT CL2940 Buttons and/or Keypad Replacement: passo 7, immagine 1 di 2 ATT CL2940 Buttons and/or Keypad Replacement: passo 7, immagine 2 di 2
    • Unscrew five 5.6 mm screws on the lower level Motherboard.
    • Keep the screws for the upper and lower level motherboard separated.
  8. ATT CL2940 Buttons and/or Keypad Replacement: passo 8, immagine 1 di 2 ATT CL2940 Buttons and/or Keypad Replacement: passo 8, immagine 2 di 2
    • Lift the lower level Motherboard upward.
    • Remove the silicon pad above the buttons.
  9. ATT CL2940 Buttons and/or Keypad Replacement: passo 9, immagine 1 di 2 ATT CL2940 Buttons and/or Keypad Replacement: passo 9, immagine 2 di 2
    • Push the Button Panel upward and pull it out.
    • Replace the entire Button Panel or a single defective button.
Conclusione
Altre 4 persone hanno completato questa guida.
IUPUI, Team 1-1, Harley Spring 2016 Membro di IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Membri
13 Guide realizzate
1Commento della guida
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 693
