Salta al contenuto principale
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
Cosa ti serve
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 2, immagine 1 di 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 3, immagine 1 di 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 3, immagine 2 di 2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 4, immagine 1 di 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 5, immagine 1 di 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 57
Tutti i Tempi: 2,163
