Salta al contenuto principale
ASUS VivoBook S400C Battery Replacement
Cosa ti serve
  1. ASUS VivoBook S400C Battery Replacement, Remove the Bottom Cover: passo 1, immagine 1 di 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Battery Replacement: passo 2, immagine 1 di 2 ASUS VivoBook S400C Battery Replacement: passo 2, immagine 2 di 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Battery Replacement, Disconnect the Battery: passo 3, immagine 1 di 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Battery Replacement, Battery: passo 4, immagine 1 di 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Battery Replacement: passo 5, immagine 1 di 1
    • Carefully lift the battery up and out of the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,072
