Salta al contenuto principale
ASUS Transformer Book Flip TP500LA Fan Replacement
Cosa ti serve
  1. ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: passo 1, immagine 1 di 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: passo 1, immagine 2 di 3 ASUS Transformer Book Flip TP500LA Fan Replacement, Back Case: passo 1, immagine 3 di 3
    • Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
  2. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 2, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 2, immagine 2 di 2
    • Slide a heavy-duty spudger between the back case and the computer.
    • Slowly work around the edges to undo the clips to fully separate the back case from the computer.
    • Gently lift off the back case.
  3. ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: passo 3, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Battery: passo 3, immagine 2 di 2
    • Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
    • Pull the blue tab to remove the ribbon.
  4. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 4, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 4, immagine 2 di 2
    • Remove the three 5 mm Phillips #0 screws.
    • Remove the single 6 mm Phillips #0 screw.
  5. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 5, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 5, immagine 2 di 2
    • Use the heavy-duty spudger to pry the white 8-pin connector away from the motherboard.
    • Gently pull the connector away from the motherboard.
    • The black 8-pin connector on the motherboard is very fragile, so be careful when removing the white 8-pin connector.
  6. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 6, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 6, immagine 2 di 2
    • Use the blue plastic opening tool to loosen and remove the three black wires from the battery.
    • Slide the battery out from the computer to remove.
  7. ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: passo 7, immagine 1 di 2 ASUS Transformer Book Flip TP500LA Fan Replacement, Fan: passo 7, immagine 2 di 2
    • Unscrew the six 5 mm Phillips #0 screws.
  8. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 8, immagine 1 di 3 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 8, immagine 2 di 3 ASUS Transformer Book Flip TP500LA Fan Replacement: passo 8, immagine 3 di 3
    • Grasp the top of the 3-pin connector with tweezers.
    • Wiggle the connector until it loosens itself from the motherboard.
    • Gently lift the connector from the motherboard attachment.
  9. ASUS Transformer Book Flip TP500LA Fan Replacement: passo 9, immagine 1 di 1
    • Carefully lift the fan off the motherboard.
    • Attached to the fan is thermal pasting that needs to be reapplied when attaching the fan back to the motherboard. Follow this guide to reapply thermal pasting correctly.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S13-G5, Forte Spring 2017 Membro di Cal Poly, Team S13-G5, Forte Spring 2017
CPSU-FORTE-S17S13G5
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,928
