Salta al contenuto principale
ASUS Q302L Hard Drive Replacement
Cosa ti serve
  1. ASUS Q302L Hard Drive Replacement, Back Case: passo 1, immagine 1 di 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Hard Drive Replacement: passo 2, immagine 1 di 3 ASUS Q302L Hard Drive Replacement: passo 2, immagine 2 di 3 ASUS Q302L Hard Drive Replacement: passo 2, immagine 3 di 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Hard Drive Replacement: passo 3, immagine 1 di 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Hard Drive Replacement, Battery: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Hard Drive Replacement: passo 5, immagine 1 di 3 ASUS Q302L Hard Drive Replacement: passo 5, immagine 2 di 3 ASUS Q302L Hard Drive Replacement: passo 5, immagine 3 di 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Hard Drive Replacement: passo 6, immagine 1 di 2 ASUS Q302L Hard Drive Replacement: passo 6, immagine 2 di 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 ASUS Q302L Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Unplug the hard drive from the connector.
    • Use a Philips #0 screwdriver to remove all four 5mm screws holding the hard drive metal mounting bracket.
  8. ASUS Q302L Hard Drive Replacement: passo 8, immagine 1 di 1
    • Use a Phillips #0 screwdriver and remove the four 5mm screws on both sides connecting the Hard Drive to the mounting bracket.
    • Remove the Hard Drive from mounting bracket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,552
