Salta al contenuto principale
ASUS G73JH-BST7 SD Hard Drive Replacement
Cosa ti serve
  1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, immagine 1 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, immagine 2 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, immagine 1 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, immagine 2 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 3, immagine 3 di 3
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
  4. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, immagine 1 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, immagine 2 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: passo 4, immagine 3 di 3
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  5. ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, immagine 1 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, immagine 2 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement: passo 5, immagine 3 di 3
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
  6. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, immagine 1 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, immagine 2 di 3 ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: passo 6, immagine 3 di 3
    • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 375
