Salta al contenuto principale
ASUS D550MA-DS01 DVD Drive Replacement
Cosa ti serve
  1. ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: passo 1, immagine 1 di 2 ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
    Chiedi a FixBot
  2. ASUS D550MA-DS01 DVD Drive Replacement: passo 2, immagine 1 di 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
    Chiedi a FixBot
  3. ASUS D550MA-DS01 DVD Drive Replacement: passo 3, immagine 1 di 2 ASUS D550MA-DS01 DVD Drive Replacement: passo 3, immagine 2 di 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    Chiedi a FixBot
  4. ASUS D550MA-DS01 DVD Drive Replacement: passo 4, immagine 1 di 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    Chiedi a FixBot
  5. ASUS D550MA-DS01 DVD Drive Replacement: passo 5, immagine 1 di 1
    • Remove the fully disconnected keyboard module from the laptop.
    Chiedi a FixBot
  6. ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: passo 6, immagine 1 di 2 ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: passo 6, immagine 2 di 2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
    Chiedi a FixBot
  7. ASUS D550MA-DS01 DVD Drive Replacement: passo 7, immagine 1 di 1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
    Chiedi a FixBot
Conclusione
IUPUI, Team 1-2, Baechle Fall 2015 Membro di IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 66
Tutti i Tempi: 788
