Salta al contenuto principale
APEX TM785CH Microphone Replacement
Cosa ti serve
  1. APEX TM785CH Microphone Replacement, Back Casing: passo 1, immagine 1 di 2 APEX TM785CH Microphone Replacement, Back Casing: passo 1, immagine 2 di 2
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Microphone Replacement, Microphone: passo 2, immagine 1 di 3 APEX TM785CH Microphone Replacement, Microphone: passo 2, immagine 2 di 3 APEX TM785CH Microphone Replacement, Microphone: passo 2, immagine 3 di 3
    • The microphone is located in the bottom center of the tablet.
    • Remove the black tape holding the wires down.
    • Remove the black tape holding the microphone in place.
    • The microphone is now exposed and can be gently pulled out of the socket.
  3. APEX TM785CH Microphone Replacement: passo 3, immagine 1 di 1
    • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
Conclusione
Baylor, Team 4-1, Williams Spring 2015 Membro di Baylor, Team 4-1, Williams Spring 2015
BU-WILLIAMS-S15S4G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 189
